Can we use flue gases of heater as an inert gas (Nitrogen)? This is for the operation of Pig launchers.
Amardeep
Posted 07 June 2017 - 11:15 PM
Amardeep
Posted 08 June 2017 - 07:26 AM
What are the constituents of the flue gas?
In general, it cannot be used since there are some undesirable materials sent to the heater or furnaces to be burnt as the flue gas.
So, it might be poisonous.
Anyhow, let us know the composition to recommend you.
Mahdi
Posted 14 June 2017 - 01:00 PM
Dear Amerdeep,
I did not see by my self but I heard from my senior that in India One of old FCC in vadodara old russian design used flue gas as a inert as after filtering. Though later on it was changed in Nitrogen after many years of successful operation.
Manoj
Posted 19 June 2017 - 10:29 PM
I used to work in a plant built in the late 60's where they used an "inert gas generator" by burning a hydrogen rich gas from a platformer or natural gas if the unit was down. I don't remember all the details, but if my menory does not fail, after the burner they sent it to a water scrubber to cool it down. It was humid, acidic (because of C02). It was anything but "inert". Today, you can get nitrogen from membranes using less energy than that unit did.
So, back to your anser, yes. You may blanket a tank with flue gas provided excess oxygen is low. But you will get into the following issues:
- It will be corrosive
- The O2 content in the flue gas will change from "combustion optimization" to "safety critical" probably requiring more instrumentation and protections.
- You will need to install condensate collection points in the distribution system
- Then you have the installation: it means the duct from the stack to your unit, a cooler/scruber and a compressor. I have not made any numbers, but probably that custom built unit is more expensive than a packaged N2 one.
Posted 20 June 2017 - 12:27 PM
I would normally not use any flue gas as an "inert" source of gas because:
I don't know what you mean by "filtering". Please explain in detail. There is nothing wrong with applying CO2, nitrogen, or flue gas composed ONLY of CO2 + nitrogen - but this is rarely the case and it costs money to clean up any contaminated flue gas. There is an old saying in Spanish: "El lavado cuesta mas que la camisa" - the laundry costs more than the shirt.
![]() Fired Heaters/ Burners/ Flue VelocityStarted by Guest_Lyne_* , 15 Mar 2024 |
Smr Reformer Flue Gas FlowStarted by Guest_kaidlut_* , 14 Feb 2025 |
Steam Requirement For Mea Reboiler - Co2 Capture From Flue GasesStarted by Guest_liquidcarbonic_* , 25 Sep 2023 |
Flue Gas Stack ModelingStarted by Guest_Maryam sheikhmohamad_* , 28 May 2023 |
Flue Gas Dew PointStarted by Guest_ganeshrbhat_* , 31 Mar 2023 |
