Hello!
I'm a recent college graduate and have been out of school for about a year now. I have been coming onto this website for a while and everyone seems incredibly knowledgeable and respectful. That being said, I've finally decided to post on here and get some help/feedback on an issue we may be having.
We will be having a methanol vent header through the plant. There will be a low point in which we have to decide how we handle the condensed methanol...Initially, my idea was to get a liquid drainer that essentially acts as a floating ball trap to drain the condensate into our wet methanol tank that is under vacuum in normal operating conditions. Under normal operating conditions we should be fine. However, should the vacuum pump ever stop, I'm afraid that the differential pressure will not be enough for the condensate to make it ~80 feet with only an elevation of ~1.5 ft into the wet methanol tank. Does anyone know of any products that would be sufficient in this application? A pump trap is ideal, but no vendor will recommend it due to liability reasons.
We've thought of possibly doing 3 AV's. One for the condensate, one for the draining, and one for a nitrogen purge line. This would all be tied to a level switch, but it seems too expensive for something that should be relatively simple.
Any help/suggestions would be much appreciated.
Cheers,
Brian
Edited by bsshin, 27 June 2017 - 12:07 PM.
