Dears: please share with me what type is goof for trasporting waste water?
Q: 6500 CUBIC METER PER HOUR
TDH:15M
BEST REGADS
M.R.Rahimzadeh
Posted 13 July 2017 - 04:04 AM
TDH:15M
BEST REGADS
M.R.Rahimzadeh
Posted 17 July 2017 - 01:46 AM
Dear Sir,
Kindly let me know if it is thick slurry or clear water & also if it is intermittent or continuous flow requirement.
SPC
Posted 17 July 2017 - 07:27 AM
Dear:
it is clear waste water and intermittenly
Posted 17 July 2017 - 03:06 PM
Dear Sir,
You may use centrifugal Pump with Level switch ( On/ off ) Provision for this Flow rate & Head application.
Also, you may float an enquiry to Pump vendors / Specialist like below to get their technical offers.
Gould Pump, Sulzer etc.
SPC
Posted 18 July 2017 - 12:46 AM
Thank you so much
Posted 18 July 2017 - 02:17 AM
waste water you may go brand tsurumi or grundfos as they have special type of impeller that allow certain size of particle and it can grind the particle. it specially made for wastewater or sewage system.
Edited by farid.k, 18 July 2017 - 02:18 AM.
Posted 19 July 2017 - 05:54 PM
Just one question.
It is right the 6500 m3/h flow requirement?
To be portable I should be a truck mounted pump with its own diesel drive or genset since power would be 400-500 kW
Pump Selection ProblemsStarted by Guest_kito-818_* , 14 Nov 2025 |
The Centrifugal PumpStarted by Guest_guoyinyanliner_* , 15 Dec 2025 |
