Hi all,
I'd like any suggestions on literature where I can find equilibrium k-values (used in industry) for aromatics components,
Thanks!
Posted 18 July 2017 - 09:39 AM
Hi all,
Thanks!
Posted 18 July 2017 - 11:04 AM
Consider using the Student Forum at this site for student-related questions.
A component's K-value (the ratio of the mole fraction of a component in the vapor phase to the mole fraction of a component in the liquid phase) depends on system pressure and temperature so is usually predicted by a thermodynamic method previously found to give good results for similar applications. At low pressures, mixtures of aromatic components can be treated as ideal so you can calculate K from the partial pressures of the components. At higher system pressures, you will get more accurate results using an equation of state like PR or SRK.
Posted 18 July 2017 - 09:34 PM
you may consider this resource to support your work .
http://www.questcons...oftware/canary/
Hope this is going to help you.
Posted 18 July 2017 - 10:44 PM
Refer the link below. The spreadsheet attached in the link has DePriester charts depicting K-values for hydrocarbons. Also extensive VLE K-values are provided in "API Technical databook":
https://www.cheresou...hase-separator/
Also refer another link for empirical method of calculating K-values for a given range of pressure:
http://www.jmcampbel...rmine-k-values/
Ankur
Edited by ankur2061, 18 July 2017 - 10:48 PM.
Posted 24 July 2017 - 11:02 AM
Much appreciated to you all! Your info was very helpful!
How To Find K-Values Of A Hydrocarbon Mixture On Aspen Hysys?Started by Guest_Alexis Azamar_* , 08 Apr 2024 |
Calculation Of Aromatics Concentration And Freezing Point In Gas StreaStarted by Guest_khattabon_* , 01 Jul 2023 |
![]() ![]() Cstr Reactor. Where Did These Values Come From?Started by Guest_chemtoli_* , 11 Apr 2023 |
Vba Values From MaterialstreamStarted by Guest_Milnesium_* , 10 Jun 2021 |
Aromatics Extraction Using Sulfolane SolventStarted by Guest_Geetanjali_* , 18 May 2021 |
