Fire Protection Of Fuel Oil Storage Tanks
#1 Sumair0994
Sumair0994
  • 6 posts
Posted 19 July 2017 - 12:05 AM
I have been given the task of designing a fire protection system for fixed roof fuel oil storage tanks. Tank details are as follows:
Diameter    = 58 m
Height        = 13 m
Product      = Fuel Oil (Class III)
Flashpoint = 70 C and above
Going through several forums, I have observed that in industrial practice for tanks storing liquids having flash point greater than 100 C use of foam system is often not recommended due to low vapor content being formed & danger of boil over, standards such as IP-19 also give vague hints of such practice. Following are my queries for this scenario:
i) whether i should install a fixed foam system?
ii) if no foam system is to be used what other alternative is to be used for fire protection/extinguishment?
iii) if water is to be used for control of burning/extinguishment, what application rates and to which surfaces should the water be applied to (roof surface, shell surface or both)?
I have already studied several standards such as NFPA 30, NFPA 15, IP-19, API 2021, API 2030 but they only provide vague hints in such scenario. So any expert advice would be appreciated.
Edited by Sumair0994, 19 July 2017 - 12:48 AM.
  • 6,720 posts
Posted 19 July 2017 - 01:29 AM
Did you consider to talk to your local fire brigade or local safety bureau ?
#3 spchauhan12
spchauhan12
  • 43 posts
Posted 23 July 2017 - 07:15 AM
Dear Sumair0994,
                          You may talk / contact to Fire system Vendors available locally to proceed further.
SPC
#4 ChemiFreak
ChemiFreak
  • 29 posts
Posted 27 July 2017 - 03:48 AM
Dear Sumair
Try using DCP
R. Mohan Babu
