Tube Expansion Percentage
tube expansion percentage
#1 sameercnn
sameercnn
  • 19 posts
Posted 02 August 2017 - 02:36 AM
Dear Sir,
In AET type heat exchangers, we have 8 shell & Tube heat exchangers needing to be re-tubed. So I am requesting your support to provide the tube expansion percentage and desired ID of the tube once the expansion percentage is reached for these exchangers.
Tube OD: 19.05 mm
Nominal wall thickness : 2.11 mm
Material : SA-179
Design Pressure tube side: 10 barg
Design pressure shell side: 8.6 barg
seal double ring expanded
Thank you,
Sameer
#2 fallah
  • 5,019 posts
Posted 02 August 2017 - 03:17 AM
Tube OD: 19.05 mm
Material : SA-179
Sameer,
I think you should refer to the latest edition of TEMA to find the response to your query...
#3 gegio1960
gegio1960
  • 518 posts
Posted 03 August 2017 - 08:44 AM
you've 8 S&THEs, TEMA type AET, to be retubed....
what is the shell diameter(s)?
what is the expansion percentage you're writing of?
