Dear Engineers,
I am creating an EDR model for the existing Reboiler, i am doing the HYSYS simulation to understand the capability of the Reboiler with the current operating conditions.
I want to get some guidance and insight into the modelling using HYSYS EDR model. I found some issues with the converged of the model due to the error in my model. I cannot match the tube count of the model to the datasheet.
the reboiler is Kettle type rebolier. With Kettle type (TEMA = B-K-U), the tube from the model very far from the user input but, when i am using X-Shell (TEMA = B-X-U) and reduce the shell ID to 750 mm tubes count match with user input. the problem with B-X-U is the input nozzle not match with the data.
I attached also the simple diagram of the reboiler and errors and warnings comment from EDR.
Can anyone help me with this problem? does anyone have done any modelling for Kettle Reboliler with HYSYS EDR?
Appreciate if you can put some thoughts or any reference of EDR model for Kettle Reboiler in this post.
Thank you,
Costa
