Pump Trimming
#1 sargon 1979
sargon 1979
  • 43 posts
Posted 27 August 2017 - 05:10 AM
Hi all;
A hot oil centrifugal pump was designed as follows:
- Motor power (Electric motor): 180 Kw.
- Motor RPM: 2980 RPM.
- Pump rated capacity : 250 m3/hr.
- pump differential pressure: 13 bar
- NPSHA: 160 m
Hot oil demand is reduced so, the pump is required to be trimmed using the following data:
- Motor power (Electric motor): 120 Kw.
- Pump rated capacity : 135 m3/hr.
Hot oil data (BP TRANSCAL N):
- Density at 0 ْC: 840 kg/m3
- Density at 250 ْC: 725 kg/m3
- Viscosity at 0 ْC: 280 Cp
- Viscosity at 250 ْC: 5 Cp
Any help please
  • 6,956 posts
Posted 27 August 2017 - 06:42 AM
sargon 1979,
To get a meaningful  answer you should supply the pump curves and also give information about the diameter of the wheel .
What is your proposal ?
Good luck,
#3 Bobby Strain
Posted 27 August 2017 - 04:48 PM
You should consult the pump manufacturer before you trim the impeller.
