What is scaling factor? What is the importance of it? I recently seen a definition which is not understandable which is mols of product per hour specified/mols of product produced per 100 kmol of the principal raw material. Could anyone help me out?
Scaling Factor
Started by sineadi, Aug 16 2006 01:14 AM
Posted 16 August 2006 - 01:14 AM
Posted 16 August 2006 - 10:30 AM
A scaling factor, in general, is just a multiplier that is used across the board to scale up for example flow rates to a different capacity. So if you have a heat and material balance for the production of say 10 kmol/h product A, and you want to generate a material balance for 15 kmol/h product A, you would multiply all "extensive" properties, such as flow rate, volumetric flowrate, enthalpy, for all streams by 15/10 = 1.5
The scaling factor is then 1.5 in this example.
Posted 17 August 2006 - 10:15 AM
QUOTE (joerd @ Aug 16 2006, 05:30 PM) <{POST_SNAPBACK}>
Erm ... scaling up is not just about using a multiplier; scaling up from a laboratory setup to a working installation entails QUITE a lot more than that.
For one thing pipes come in standard sizes / diameters (so a scale factor alone doesn't suffice). With reactors scaling up is VERY tricky, you want to avoid 'dead zones' (especially in biological processes). Etcetera etcetera.
Posted 17 August 2006 - 12:14 PM
I agree, I was just referring to material balance data. Sorry for being incomplete.
![]() Colebrook's Equation - Friction FactorStarted by Guest_breizh_* , 10 Nov 2024 |
C Factor For Erosional Velocity For Multi-Phase Flow (Nat Gas/ ProduceStarted by Guest_Sam11_* , 10 Sep 2024 |
![]() Determining The F-Factor Following The Api 2000Started by Guest_Hachimi_* , 06 Sep 2024 |
![]() Environmental Factor "f" Calculation In Psv Fire CaseStarted by Guest_mahmooddalvi09_* , 17 Aug 2024 |
![]() Wind Enhancement Factor In Kumana Kothari CalculationsStarted by Guest_rlepra_* , 01 Dec 2017 |
