MS-01-176.PDF 1.54MB 17 downloadsI have been going through online check valve manual. I have found two technical terms in that. Nominal cracking pressure and cracking pressure range. I know that cracking pressure is that pressure at which first indication of flow occur. This means that cracking pressure is single value, then why does cracking pressure range is specified.
I have attached technical specification file for your reference.
Thank you in advance
Edited by Ullhas11, 30 August 2017 - 01:57 AM.
