Is there any formula to calculate moisture in ppm with dew point analyser reading especially in the platformer recycle gas?
Moisture Analyser
Started by dilip, Aug 17 2006 09:40 AM
Posted 17 August 2006 - 09:40 AM
Posted 17 August 2006 - 10:10 AM
Where I work a method is used to compensate the combustion air flow to compensate for moisture content, this is based on an electronic sensor measurement (simple) of the outside air. Our PROBLEM is that the value obtained needs a HELL of a formula to process it (basically a BIG nested formula to approximate a curve).
I bet you'll need more specific data on the gas (mixture) in your system, BOTH to obtain a workable calculation method AND to determine which sensor you have to use to obtain measurements for it.
Posted 03 March 2009 - 11:36 PM
You can download a freeware calculator from www.phymetrix.com that will perform all of these conversions.
Hope this helps!
Hope this helps!
![]() Moisture Removal From Blower AirStarted by Guest_Makarove_* , 12 Jul 2024 |
![]() Water In Diesel Due To Condensed Moisture From Air Ingress From VentsStarted by Guest_omideng_* , 28 Oct 2021 |
![]() Applicability Of Pv = Nrt For Flue Gas And Moisture Content MeasuremeStarted by Guest_cheminst_* , 17 Jun 2019 |
Calculate Moisture Adsorbed In Adsorption BedStarted by Guest_Abm_* , 20 Jun 2018 |
Protection Against Moisture Os The Water SteamStarted by Guest_Movers_* , 13 Feb 2018 |
