Two-phase Flow Pressure Drop Calculation In A Pipe
Posted 17 August 2006 - 06:18 PM
I am looking for information regarding pressure drop calculation of two-phase fluid in an elevated pipe.
I found that Beggs and Brill correlation is a common practice.
Request: I need correlations for pressure drop due to:
1. friction
2. accelration
3. static head
For a straight pipe, i think the total pressure drop = pressure drop due to (1+3)
Suresh
Posted 18 August 2006 - 03:42 PM
In the profesional forum of this site treats about your question look at:
http://www.cheresources.com/invision/index.php?showtopic=2659
and if you send me your e-mail direction, I will send you information via e-mail.
Good luck.
Posted 18 August 2006 - 08:06 PM
Thanks for your reply.
My e-mail: sureshreddy_50@yahoo.co.in
Suresh
Posted 22 August 2006 - 04:22 PM
I sent by e-mail the information I promissed
If you donĀ“t receives, please tell me for look alternate way for sending.
The file is abour 6 Mb. in acrobat.
Posted 04 October 2006 - 09:44 AM
I can see that ur online,
Will u send me the same file u sent to Mr, suresh....
I am also one of the interested candidate to learn two phase phenomena
Email: jetul@rediffmail.com
thanks
bye
Posted 10 October 2006 - 07:59 AM
I need to take issue with one statement you made earlier. The acceleration losses have nothing to do with whether the piping is straight or not. There will be acceleration losses (or gains) everytime there is a change in the fluid's velocity. Acceleration is most important in two phase flow (especially when flashing), less so in gas flows, and usually neglected in single phase liquid flow. (This, of course, is an oversimplification since even in liquid flow you consider entry and exit losses, which are acceleration losses.)
Posted 17 October 2006 - 07:54 AM
I tried to sent you the files that you requested me, but for the size of file was impossible.
Instead, I attach an PDF file about Two phase flow and its worksheet for aplication
I think that this information will be useful to you
Posted 19 October 2006 - 03:27 AM
Caution should be taken when you are using only two parameters to determine flow pattern in two phase flow pipes:
Taitel and Dukler discussed various available coordinate systems, and argued that flow pattern transitions can not all be described by any one coordinate pair.
Ragards
Ebrahim
Posted 12 September 2008 - 02:18 AM
my mail id is vinee43@yahoo.com, kindly send me the documents.
Vinee
Good luck.
#10
Posted 12 September 2008 - 02:35 AM
What can be more general than Fanning equation?
If you use Google for exploring the topic "pipe friction losses", you'll find thousands of on-target results.
Best regards,
#11
Posted 12 September 2008 - 10:24 PM
I am also interested in two-phase problem,
could you send the file to me? thanks a lot.
my e-mail: d933652@oz.nthu.edu.tw
#12
Posted 02 May 2011 - 03:47 AM
i'm designing a shell & tube condenser, in wich the condensation is in the tube side. i am trying to calculate a two phase pressure drop but can't find a good info related to this problem. Would you please send me the information that you've sent to another user of this forum?
My e-mail address is: antonfedak@gmail.com
Thanks in advance!
Anton
#13
Posted 09 October 2011 - 11:37 PM
Hi Suresh
If you don´t receives, please tell me for look alternate way for sending.
Pressure Control In Batch Distillation ColumnStarted by Guest_Femi_* , Today, 03:40 AM |
Maximum Natural Gas Flow Through OrificeStarted by Guest_ukrche_* , 10 May 2024 |
Dp Drop In Structured Packing Amine Absorber Causing IssuesStarted by Guest_kek12345_* , 10 May 2024 |
Age Impact On Pipe RoughnessStarted by Guest_Noman97_* , 09 May 2024 |
