Pressure Drop On Gas Pipeline Hysys
#1 LizbethR14
LizbethR14
  • 3 posts
Posted 20 September 2017 - 06:02 PM
I compared the results of pipe segment in Aspen HYSYS for a wet gas pipeline of about 8 kilometers long with actual field data, and found that it over predicts the pressure drop. Other than varying the roughness, what other changes can I make to close the gap?
Edited by LizbethR14, 20 September 2017 - 06:02 PM.
#2 Bobby Strain
Posted 20 September 2017 - 06:58 PM
You might want to give us some screen shots from HYSYS. Along with the calculated and measured values. Have you checked using other correlations?
#3 serra
serra
  • 311 posts
Posted 21 September 2017 - 03:38 AM
LizbethR14,
you should provide additional data or contact technical support,
for example, a different correlation can predict a different pressure drop,
in the same way a different thermo package can predict a different density or amount of condensate etc. etc.
recently, for a 2 Km pipeline, with another software (Prode Properties)
i have found up to 7% differences (selecting different correlations, EOS etc.)
but that depends from the specific application.
#4 Pan Nata
Pan Nata
  • 34 posts
Posted 21 September 2017 - 09:24 PM
LizbethR14,
You have to check what kind of correlation that you use for the simulation, your pipeline is new or not, whether your pipeline bathymetry is correct or not.
#5 chocobang
chocobang
  • 65 posts
Posted 22 September 2017 - 12:19 AM
Or check other software
http://www.korf.co.uk/korf_links.html
#6 chocobang
chocobang
  • 65 posts
Posted 18 September 2019 - 06:54 PM
Hi Lizbeth14,
A white paper produced by Aspen for multiphase flow shows Beggs and Brill over-predicts pressure drop for horizontal and incline pipelines. They suggested using Tulsa Unified, HTFS and Gregory et al. models.
Cheers,
Chris
