Dear All
Presently I am working on project- refrigerated LPG terminal facility. at terminal refrigerated propane at -42 DEG C needs to be heated to 15 DEGC in order to do blending it with Butane ( LPG MIX - Propane & Butane 50: 50) and further store the LPG mix in Pressurized Bullet TANKS.
I am looking for most economical option for heating propane by doing value engineering. presently Propane heating is proposed by using sea water ( In / out temperature is 25 & 20 Deg C respectively ) . I had searched for technical papers & found that Ambient air vaporizer is the better alternative or option for sea water heating.
Seeking for valuable suggestion or advise from respected forum members .
VP
