What is the definition of liquid entrainment rate in demisters? is it the flow rate of liquid in the stream that it will enter through demister ?
And what does it mean when liquid entrainment rate is equal to total liquid flow rate in feed !
Posted 06 October 2017 - 08:28 AM
Posted 06 October 2017 - 10:09 AM
Chemeng92,
Suppose you mean the demister at the top of a separator:
Yes, it's the carried over liquid flow rate passing through the demister...!
If the liquid entrainment is equal to total liquid flow rate in the feed; means no separation being performed which followed by a zero efficiency demister...!
Posted 06 October 2017 - 11:16 AM
That is either called, or is similar to, "flooded".
Posted 06 October 2017 - 11:23 AM
Chemeng92,
Yes it is top of knock out drum .
It is weird because the demister supplier in datasheet they put 99% effeciency with total liquid flow rate equal to liquid entrainment !
Posted 06 October 2017 - 12:42 PM
You can get help if you don't withhold information. We are not clairvoyant.
Posted 06 October 2017 - 01:18 PM
Please upload the data sheet...
Posted 07 October 2017 - 03:30 AM
a bit of literature to support your work.
Pressurizing LiquidStarted by Guest_Ahmadhamzahperta_* , 02 Apr 2025 |
Modeling Liquid-Liquid Membranes In Aspen PlusStarted by Guest_bodinjas_* , 18 Mar 2025 |
