General Causes Of Centrifugal Pumps Failure
talha
9 replies to this topic
#1 parco
parco
  • 6 posts
Posted 11 November 2017 - 01:40 PM
How can we avoid centrifugal pumps failure?
#2 fallah
  • 5,026 posts
Posted 11 November 2017 - 02:07 PM
In general, by well specifying, prepare from reputable vendor and proper operation...!
#3 Kachisa
Kachisa
  • 77 posts
Posted 11 November 2017 - 03:28 PM
First thing, you should know what causes your pump failure before looking for an answer.
#4 Bobby Strain
Posted 11 November 2017 - 05:27 PM
Proper selection, installation, operation, and preventative maintenance. Regular inspection during operation.
#5 parco
parco
  • 6 posts
Posted 12 November 2017 - 11:46 AM
Most of the problems are mechanical seal leakage and pump bearing replacement due to high vibration. What are the best operational practices, if we adopt then we can prolong pump failure duration. Thanks.
#6 ankur2061
ankur2061
  • Forum Moderator
  • 2,484 posts
Posted 12 November 2017 - 12:12 PM
Parco,
Why don’t you go through the centrifugal pump troubleshooting checklist at the link provided below:
https://www.cheresou...ting-checklist/
This may help in preventing pump failures.
Ankur
#7 Bobby Strain
Posted 12 November 2017 - 12:47 PM
Many problems are caused by two things. The first is operating the pump with a flow less than the minimum flow recommended by the manufacturer. If you operate below this value, the ensuing shaft deflection causes both bearing and seal failures. The second is pump cavitation that results from insufficient NPSH. Vibration is the result.
#8 breizh
  • 6,939 posts
Posted 12 November 2017 - 01:43 PM
http://centrifugal-p...rg/sitemap.html
http://www.mcnallyin...2-html/2-7.html
http://www.pumpfunda...e.htm#download6
To me your question is too vague , Consider the links /resources attached to learn about Centrifugal pumps .
Definitely Bobby's comments are right . Being more specific you should get a better answer .
Good luck,
Edited by breizh, 12 November 2017 - 01:51 PM.
#9 breizh
  • 6,939 posts
Posted 13 November 2017 - 09:30 AM
in addition to my previous answer .
#10 parco
parco
  • 6 posts
Posted 13 November 2017 - 10:52 AM
Hi Breizh / Boby / Ankur
Thank you very much for providing valuable information.
