Low Velocity Heat Exchanger Issues
Started by SadiqChemy, Nov 17 2017 04:32 AM
Posted 17 November 2017 - 04:32 AM
If I have to design heat exchenger between same fluid and the flow rate of these fluids are very small ( around 3300 lb/h ) . If I got positive overdesign but the velocity of shell fluid and tube fluid very low ( less than 0.2 m/s) . Is that problem ? Will that result fouling problems ? The fluids are glycol solution.
Posted 17 November 2017 - 03:35 PM
Low velocities can b a problem unless there is good filtration of the glycol. At low velocity the glycol can pick up undesirables like rust and sand.
Posted 18 November 2017 - 04:09 AM
So , using twisted tape is recommended.?
What about shell fluid ? I reduced baffle spacing , cut and still velocity is too low !
Posted 18 November 2017 - 10:38 AM
The lean solution should be in the shell side since it would have less undesirables.
Lng ExchangerStarted by Guest_guoyinyanliner_* , 10 Feb 2026 |
Best Heat Exchanger Type For Gas HeatingStarted by Guest_Gole_* , 29 Jan 2024 |
Velocity In A Vertical Pipe Or Open PipeStarted by Guest_jango_* , 02 Dec 2025 |
