Wind Enhancement Factor In Kumana Kothari Calculations
8 replies to this topic
#1 rlepra
rlepra
Posted 01 December 2017 - 01:30 PM
I am using the spreadsheet supplied here for calculation for "Heat loss calculation in a vertical and horizontal tank and in a pipeline"
The spreadsheet and guide provides by Enrico Lammers are superb! But the doubt I have is on the original paper from Kumana and Kothari,
in this paper the Wind Enhancement Factor plot shows that the factors are lower when the delta-T increases, I find this surprising,
since the higher the temperature of the surface it seems intuitive to me that the highest the temperature on the surface the faster the
will flow to the air closer to the surface, so for a constant wind speed, the factor should increase as the difference in temperature
increases. What am I missing?
thank you in advance for your help.
Rafael
  • 6,940 posts
Posted 01 December 2017 - 07:16 PM
hi Rafael .
Please consider the document attached .
Hope this is helping you.
#3 adilmech01
adilmech01
Posted 24 June 2022 - 04:09 AM
Hi, I have a same question like Rafael. Please reply.
Thanks,
Adil
hi Rafael .
#4 breizh
  • 6,940 posts
Posted 24 June 2022 - 05:01 AM
To reply to your query a few documents attached .
Enjoy the reading
#5 ptvu2672
ptvu2672
Posted 09 June 2024 - 09:55 PM
Hi, I cannot find the document you attached. Could you please show me where it is?
Thanks a lot
hi Rafael .
#6 breizh
  • 6,940 posts
Posted 09 June 2024 - 10:22 PM
For your support.
#7 vsnlbom
vsnlbom
  • 27 posts
Posted 04 July 2024 - 03:42 AM
Cant find any spreadsheet and other attachments discussed in post.
Rafael
#8 breizh
  • 6,940 posts
Posted 04 July 2024 - 04:07 AM
Is it a normal way to ask for support ?
https://www.cheresou...ss-calculators/
#9 vsnlbom
vsnlbom
  • 27 posts
Posted 04 July 2024 - 11:24 PM
I  always try to find answer based on available threads and other resources. This thread topic looked interesting to me for enhancing knowledge. However, documents were not able, that's why requested to post. Thanks for the links.
