Good day all Experts,
We are facing problem of sudden drop in lean amine flow to amine contactor which caused amine circulation and amine booster pump trips due to low low discharge flow at one of our Gas Treatment facilities. Based on data analysis we found that lean amine flow control valve on amine circulation pump discharge line to amine contactor was opened but the flow started to drop suddenly which caused the amine circulation pump on low low discharge flow. This incident was repeated 3 times in last 6 months which is causing production loss.
During this incident it was observed that amine circulation pump discharge pressure increased at the same time when lean amine flow dropped to low low which tripped the pump. Here it is worth to mention these pumps are provided with min flow recycle valve which was originally provided with a logic to open at low flow condition to save pump from tripping. But later on a new logic was created to open this min flow recycle valve on high discharge pressure of pump. So during the trip incident when the pump discharge pressure increased then min recycle valve opened up to 70~ but even then pump tripped due to low low flow conditions. Actually new logic was change in original design to control the high discharge pressure of pump and vibration on lean amine flow line to Amine Contactor. So now the pump min recycle flow is working low flow & high discharge pressure based on high selector.
During plant data analysis before the trip incidents we found that when pump discharge pressure increased, min recycle valve opened up to ~70% and then we observed high pressure drop across lean amine cooler on suction side of the pump. We also observed that lean amine flow control valve on pump discharge line to amine contactor was open 50~% but pump discharge pressure started to open and then pressure increased further. lean amine flow control valve opening reached upto 100% but pressure increased maximum and then it open the min flow recycle valve 70%. But still pump tripped on low low flow.
Based on plant data analysis we found that all process parameters including feed gas pressure, amine absorber, flash drum and Stripper levels, Amine Absorber and stripper DP was normal. Also we check the amine quality it was good. Then we concluded that low low at pump discharge was occurred due to high DP across the lean amine cooler which was created due to opening of pump min recycle valve.
But still we can not clearly pin point the true cause for the pump trip due to low low flow conditions. I need your expert opinion regarding the stated problem. I have also attached herewith the Unit PFD with detail system description.
