Air Separation Unit Hysys
8 replies to this topic
#1 keyser soze
keyser soze
  • 3 posts
Posted 15 December 2017 - 09:14 AM
hello
is anyone skilled in creating aspen hysys simulations of air separation units? i am looking into a study that provides 71kg/s of gaseous oxygen and having difficulty with converging the LNG heat exchagners and LP/HP columns. any help/guidance would be greatly appreciated.
cheers
#2 Padmakar Katre
Padmakar Katre
  • 992 posts
Posted 03 January 2018 - 05:34 AM
keyser soze:
cheers
I have an ASU model, I don't recall the source, might have prepared as part of Hysys training program.
I am enclosing herewith, hope it helps.
  • Attached File  ASU.zip   283.89KB   348 downloads
#3 keyser soze
keyser soze
  • 3 posts
Posted 03 January 2018 - 06:30 AM
Padmakar S Katre:
thank you for your reply. it seems the file you have shared was built in a newer version of aspen hysys and i cannot open it on my older version. it is reading the following error: 'file asu.hsc was created in build 100249 and cannot be read by build 90270.'
are you able to transform it to an older version?
many thanks
#4 Padmakar Katre
Padmakar Katre
  • 992 posts
Posted 03 January 2018 - 07:18 AM
keyser soze:
Yes it's in latest version of Aspen V10.  Ok, let me send you the older version file.
  • Attached File  ASU.zip   201.69KB   224 downloads
#5 keyser soze
keyser soze
  • 3 posts
Posted 03 January 2018 - 07:58 AM
recieved. thanks for your help, much appreciated
#6 stratovona266
stratovona266
  • 10 posts
Posted 19 January 2018 - 01:33 PM
Do you guys happen to have a a cryogenic air separation unit model that only produces oxygen? Or do you guys know of a book or paper where I can find the necessary information for modelling the air separation unit? Something I can reference to.
#7 ciamba87
ciamba87
  • 9 posts
Posted 17 April 2018 - 06:49 AM
I share the stratovona266's request. Moreover I miss some aspects in the simulation that Padmakar Katre attached: how can we remove the very low temperature coming from the argon column reboiler?
#8 EdenHuang
EdenHuang
  • 4 posts
Posted 12 June 2018 - 07:19 AM
ciamba,
it was removed by a part of oxygen-enriched liquid air from the bottom of  HP column
#9 ciamba87
ciamba87
  • 9 posts
Posted 13 June 2018 - 03:17 AM
EdenHuang,
Thank you for your answer, but still I cannot understand.  Firstly I made a mistake: I did not refer to boilerbut to the condenser of argon column.  Anyway, if I understood your solution is shifting part of the oxygen-enriched liquid coming from the HP column to the argon column: but the system is slightly balanced and this solution could cause a lack of "cold" in the LP column, and so there will not be an equilibrium between the HP and the LP column.  Am I wrong?
