Oleum Generation
Posted 16 December 2017 - 02:25 AM
In sulphination plant,
So3 is generated (air +so3(6%))
Air has dew point -65 degree celsius
Oleum is undesirable product
How should i calculate amount of oleum generated.
Posted 18 December 2017 - 11:17 AM
Because this is in the student forum, I am going to assume that this is an educational exercise. I would note that it is not our purpose as a forum to short-circuit your education by doing your homework for you. A few questions and thoughts that will help us help you:
1) I think there is some value in giving us some background on you -- what course is this part of? What part of that course? Where are you at in your studies? I could see different levels of detail for a first year chemistry student compared to a post-doc student.
2) It seems like there should be more basic information that you can give us: Reaction or reactions you are considering, constants related to those reactions (equilibrium and rate constants potentially seem pertinent to this problem), other preliminary work you have done to show us how you think you will solve the problem.
3) After a couple of days, what efforts have you made to solve the problem? What parts are you understanding and what parts are you really struggling with? There are potentially many different lectures and lessons that feed into a problem like this. A specific question about the parts/lecture topics that you don't understand is much better than a broad, open question where we may potentially need to recreate several lectures worth of material.
We won't do your homework for you, but we are happy to help if you can show us what you have tried and where you are stuck.
Power GenerationStarted by Guest_Chari_* , 17 Oct 2026 |
Convertor Performance For Sulphuric Acid GenerationStarted by Guest_Ranga v_* , 01 Jun 2026 |
Ammonia Line Vapor GenerationStarted by Guest_simadri_* , 07 Apr 2025 |
Is There Any Rule Of Thumb For Estimation Of Steam Generation From FirStarted by Guest_AnbIran_* , 20 Nov 2023 |
