Hi, I have modeled methane gas separator process as attached file. (I want to upload HYSYS hsc. file, however there is note saying 'You're not permitted to upload this kind file' so only image file)
Current process is simple, Feed LNG is fed to tank and goes to vaporizer, then go to separator. Vapor from separaror goes to consumer and liquid such as ethane, propane etc. in the separator goes back to tank as recycle.
1. What I am wondering first is why mass flow rate increase as recycle iteration number is increased in the steady state.
2. Finally what I am trying to do is dynamic simulation after steady state setting.
Intended process is same as the attached file, however the different is that feed stream valve is closed (meaning no feed stream) and LNG liquid flow to vaporizer will be made from initial holdup in the tank.
So the tank will have 2 outlet streans(Boil off gas and LNG liquid flow to vaporizer) and 1 inlet(heavy hydrocarbon such as ethane and propane etc).
After then I expected to see how LNG composition in the tank will vary as time goes.
As I am begainer to HYSYS, so not sure whether the mentioned process above can be solved through HYSYS.
Please anyone help me.
Thanks.
Edited by lee1706, 02 January 2018 - 11:10 PM.
