Edited by raman123, 03 January 2018 - 12:24 PM.
Posted 22 December 2017 - 12:05 PM
Posted 23 December 2017 - 01:39 AM
RS,
We have to suppose both tank and truck are pressure vessel.
A moment after pumping the pressure in the truck will be 95 psig. No problem for pumping due to pressure equalizing in tank and truck.
Posted 23 December 2017 - 05:37 AM
hi
the transfer of LPG to the truck by pump: in this case the LPG is totlay liquid because the aspiration line of pump is connected to the bottom line of tank or sphere the total pressure is the vapour pressure + the pressure of LPG liquid.
i think there is no equalisation of pressure between truck and storage tank because in manu cases we transfer LPG without pump (pressure diffrence) and if we have equilibrium the pump is started.
Pipe Fluid Temperature Increase Due To Solar LoadingStarted by Guest_HeemeshJ126_* , 06 Apr 2016 |
Truck LoadingsStarted by Guest_panoska_* , 20 Jul 2023 |
Acid Gas Cleaning Using Mdea - Low Loading?Started by Guest_knvrmnd_* , 28 May 2022 |
Thiophosgene Loading To ReactorStarted by Guest_F.Baksay_* , 25 Apr 2022 |
Reciprocating Compressor Loading StepsStarted by Guest_Divid Kelin_* , 14 Dec 2021 |
