Fired Heater Forced Draft Fan Curves
#1 CHEMSTRONG
CHEMSTRONG
  • 348 posts
Posted 30 December 2017 - 02:58 PM
Hi All,
I have a query w r t Fired Heater Forced Draft Fan Performance curves. I have a furnace for CDU which has combustion air FD fan .I am trying to simulate fired heater in hysys.
FD fan datasheet has curves in it as capacity in m3/ min vs static pressure in mm water column . Datasheet also mentioned that suction pressure is -30 mm water column and discharge pressure is 200 mm water column .In Hysys,  curves are put in the form of head vs capacity. I want to know how to convert static pressure in mm WC to head in m .? Request your help with detailed explanation.
  • 6,940 posts
Posted 30 December 2017 - 08:23 PM
hi ,
- Probably good for you to find a unit converter , A very good one is Uconeer from our colleague Katmar .
1013mbar=10.33 m wc ;  1 bar =100kpa
- Pressure should be expressed in absolute (suction pressure) , not vacuum
https://www.nyb.com/...tters/EL-03.pdf
hope this is helping you
Edited by breizh, 01 January 2018 - 06:02 AM.
#3 CHEMSTRONG
CHEMSTRONG
  • 348 posts
Posted 31 December 2017 - 08:28 AM
Dear Sir,
When we say static pressure , is it suction pressure or discharge pressure of fan ? WHY IT is called static pressure then ? Also generally , we use density*acceleration due to gravity* height for liquud contained in tanks or vessels as hydrodynamic head. This is Combustion Air fan which is gaseous system. I THINK we can nt use this formula for gases.. Please guide me if I m wrong in my undestanding ?
Please clarify in details how to convert this static pressure into head in m accurately.
#4 breizh
  • 6,940 posts
Posted 01 January 2018 - 02:27 AM
http://www.klmtechgr...stems_Rev01.pdf
Hope this is helping you , on top what was supplied before !
Edited by breizh, 01 January 2018 - 06:09 AM.
#5 CHEMSTRONG
CHEMSTRONG
  • 348 posts
Posted 01 January 2018 - 03:55 AM
Respected Sir,
I went through the documents. But i did nt get how to convert static pressure in mm water column into head in m now. Please help me. If it is a liquid, i would have found out by simply using hydrodynamic relation. But it is air . So how to convert it ?
Regds,
Chetan Chavan
#6 Padmakar Katre
Padmakar Katre
  • 992 posts
Posted 03 January 2018 - 12:50 AM
Hi All,
You can simply use the static pressure vs air flow curves in simulation. I presume you are using compressor template in Hysys since no fans or blowers has separate template.
#7 CHEMSTRONG
CHEMSTRONG
  • 348 posts
Posted 03 January 2018 - 09:15 AM
dear Padmakar Sir,
I m using UniSim Design wherein one can not put static pressure vs capacity in Curves option.
Please advice me some solution to this problem. I can put only head vs flow therein..
Chetan Chavan
