I am experiencing a problem in HYSYS v3.2 & I hope guys here help me out. The problem relates to the electrolytes component list which is EMPTY (which I want to use with OLI fluid package) & HYSYS constantly says
Unable to locate Electrolyte Databanks!
I am attaching x4 images in sequential order to display the problem....
Even if there are no databanks in my local PC (don't know why aren't they installed) this link:
http://wiki.olisyste...ith_Aspen_HYSYS
states that I can manually use/add OLI databanks given the proper format (for each databank there has to be 39 files). So I requested OLI databanks (public domain) from my admin. Three of these databanks I copied to another directory & using the link's instruction above (http://wiki.olisyste...a4/Custom_1.jpg) tried to custom add the databank but NO SUCCESS! (refer to 4th image & the archived file containing these x3 databanks). The name of the x3 databanks are the same as x3 .DIC files
Archive: http://www.mediafire...pnd2pdt/oli.zip
Kindly please someone reproduce my error or check what is the location in his/her PC for the databanks I may have to change only the location!
