Hello everyone,
I'd be grateful for any advice on the design of my CO2 absorption unit within an Ammonia plant, thank you in advance for all replies.
Context:
I am using activated MDEA (aMDEA) at a concentration of 30 wt% MDEA, 3 wt% Piperazine (PZ) with the remaining solution being water, it enters the column at 32 degC. The gas stream from which CO2 is being removed enters at 35 degC and contains:
H2O = Neglibile
CH4 = 0.69%
CO = 0.2%
CO2 = 17.87%
H2 = 61.42%
N2 = 19.5%
Ar = 0.23%
Total Flowrate = 224,910 kg/hr
Much of the literature I have read suggest that both Aspen Plus and HYSYS model the reactions between CO2, MDEA and PZ poorly, as I don't have access to software such as ProMax or ProTreat I have opted to base my design off of experimental data. Using a paper which gave partial pressures and CO2 loading across a range of temperatures I have formed a model in Matlab which accounts for the high heat of reaction.
Edited by AyrtonB, 28 January 2018 - 08:58 AM.
