Hi Folks,
I have the velocity and Mach numbers through a flare header system. One scenario where Mach 1 is predicted at an intermediate pipe, not upstream, nor downstream at the discharge point. This stretch of pipe has ells, a tee, and a valve. A couple of questions.
(1) Could someone share a link or a resource to using the velocity to calculate the noise in db? I see a lot of affiliated discussions online, but don't see exactly what I need.
(2) Would excessive noise be expected at the ells, the tee, and the valve, but not the pipe? That is, if I put on acoustic insulation at the ells, the tee, and the valve, and a few pipe diameters upstream and downstream, would that typically address the situation?
Thanks,
Motrack
