Valve Characteristic Curve In Control Valve Sizing Sheet
control valve sizing valve characteristic % opening cv gas service
#1 freester
freester
  • 4 posts
Posted 01 March 2018 - 10:14 AM
I'm trying to size a control valve for gas service and i'm struggling to plot the valve characteristic curve for a linear and equal percentage valve.
Has anyone build a spreadsheet that plots the calculated CVs of the valve on the valve charecteristic curve? For example, in order to check if the selected valve cv operates within acceptable range 20%-80%?
thanks in advance
#2 Nikolay_
Nikolay_
  • 169 posts
Posted 23 March 2018 - 08:55 PM
Try tables of valve manufacturers.
#3 astro
astro
  • 121 posts
Posted 04 April 2018 - 01:33 AM
Searching this forum yields some answers:
https://www.cheresou...haracteristics/
https://www.cheresou...ft-calculation/
(one for next time)
Some other links:
http://pointing.spir...acteristics.asp
http://cgproducts.jo...T_PDF/347VB.PDF
When you've built your spreadsheet, it might help others if you posted the results of your effort.
