Dears,
What is the best flow measurement technology for viscous materials? I've done a quick search and found that coriolis is recommended in many web site. However, my service does not need high accuracy such that of coriolis flow meter (and high cost). Is it possible to use differential pressure flow meters (e.g. orifice)? The fluid viscosity is in the range of 200 to 400 cSt.
Flow Measurement Of Cold Bottom Of Barrel Products
Started by Vegeta, Mar 06 2018 10:23 AM
Flow Through A Perforated PlateStarted by Guest_Ahmadhamzahperta_* , 13 Feb 2026 |
Gas-Liquid Pipe Flow Friction Loss CorrectionStarted by Guest_Huba_* , 18 Dec 2025 |
Software For Calculating Flow Through A PipeStarted by Guest_Deep24_* , 07 May 2018 |
