Reid Vapor Pressur Of Heavy Gas Oil In Operations Conditions (Or Any M
#1 titim
titim
  • 76 posts
Posted 08 March 2018 - 07:08 AM
hi, how can i determine the TVR of a hydrocarbon (heavy gas oil or any mixture of hydrocarbons.), at T and P except the standard conditions (conditions for heavy gas oil T =300 °C and P=2.8atm). Best regards
Edited by titim, 15 March 2018 - 07:26 AM.
#2 PingPong
PingPong
  • 1,474 posts
Posted 08 March 2018 - 07:31 AM
What does TVR mean?
#3 titim
titim
  • 76 posts
Posted 15 March 2018 - 07:21 AM
TVR : Reid vapor pressure
#4 serra
serra
  • 311 posts
Posted 15 March 2018 - 12:38 PM
ASTM D323 - 15a Standard Test Method for Vapor Pressure of Petroleum Products (Reid Method) describes how to to determine the vapor pressure at 37.8 °C (100 °F) of petroleum products and crude oils with initial boiling point above 0 °C (32 °F),
if you know the composition you can simulate Reid Test and calculate the Reid Vapor Pressure which is slightly different from the True Vapor Pressure (the bubble point of the mixture) ,  many simulators includes procedures for estimating the Reid vapor Pressure, for example my copy of Prode Properties includes the method StrRVP() exported in Excel as macro which returns the Reid Vapor Pressure calculated according D6377 (liquid not saturaed with air) or D323 (liquid saturated with air) ,
as said you can calculate the True Vapor Pressure (bubble point) which normally is not too different from RVP...
