We have a haldor topsoe reformer where Fuel NG appx. 2800 nm3/hr is preheated from ambient 25-30 deg C to 60 deg C by using 33barg saturated steam (not in fluegas heat recovery path). Combustion air is preheated in flue gas recovery path to 270 deg C. Flue gas final temp. is 115-120 deg C. If we heat fuel NG to furthur high temperatures, will it be beneficial? How? Thank you
Benefit Of Ng Preheating For Reformer Fuel
Posted 05 May 2018 - 03:07 AM
2800 Nm3/h NG gives a fired duty of about 28000 kW (based on LHV). On top of that comes the fired duty of the PSA tail gas.
Preheating 2800 Nm3/h NG from 25 to 60 oC adds a duty of only 45 kW.
As you can see, preheating fuel gas has a negligeble effect on furnace performance, which is why normally nobody does it (except sometimes in gasturbines). Combustion air quantity is many times bigger and therefor more suitable for preheating.
In your case it is moreover questionable whether the small effect is worth the value of the HP steam.
Sometimes the NG is supplied at high pressure, and is therefor preheated upstream the control valve so as to avoid too low temperature downstream the control valve (due to Joule-Thomson cooling) and risk of hydrate formation. That could be the reason why in your unit the NG is preheated a little.
Posted 26 May 2021 - 05:55 AM
I suggest you begin a new thread with your question (instead of posting your question in an old thread.) That will help avoid confusion for everyone. Explain the problem you have and include enough details to perhaps get a useful answer. For your question, details might mean equipment size, type, configuration, fuel, history of performance, recent changes, solutions already tried, your role in finding a solution, etc.
Handheld Ethanol Fuel Content AnalyzerStarted by Guest_Sciosophy_* , 03 Mar 2026 |
Smr Reformer Tube Hot BandStarted by Guest_kaidlut_* , 07 Aug 2025 |
Smr Reformer Flue Gas FlowStarted by Guest_kaidlut_* , 14 Feb 2025 |
Sugar Impurities After Distilling Ethanol FuelStarted by Guest_vyse_* , 14 Nov 2024 |
Calculation Of Approach To Equilibrium Of Primary Reformer CatalystStarted by Guest_muthukmaar_* , 05 Jul 2019 |
