I'm doing a dynamic simulation in which after i completing the static simulation if I go to dynamic simulation every stream in the simulation gives incorrect answer and the integrator stops. Now I deleted every block and then started by going forward one by one and narrowed down the problem in the both my mixers.Both in going streams are at their respective flow and pressure but the out going stream have a minus flow .dynamic specification is on equalize all.what might be the problem??
please help if you think of anything .i'm almost out of time for my class project so any suggestions cam be a great help.tnx
