Spool Installation Upstream Of Psvs
9 replies to this topic
#1 R.Ahmadi
R.Ahmadi
  • 10 posts
Posted 18 May 2018 - 09:36 AM
Dear all
why is a spool installed upstream of PSVs flange to flange of the relevant vessel
#2 fallah
  • 5,019 posts
Posted 18 May 2018 - 10:20 AM
Hi Ahmadi,
That pipe spool actually is to be installed there as a "positive isolation" facility; hence, in maintenance cases this spool will be removed and the vessel flange will be blinded.  Then, as the blind has to be removed before spool re-installation, there would be no safety issue due to forgetting to change the spectacle blind status from close to open by operator in the case without a spool installation.
#3 R.Ahmadi
R.Ahmadi
  • 10 posts
Posted 18 May 2018 - 11:24 AM
Dear Fallah
thank you for your attention to my questionquestion and your comprehensive answer.
In conclusion,using an end blind flange instead of spectacle blind is the reason, isn't it?
#4 fallah
  • 5,019 posts
Posted 18 May 2018 - 12:08 PM
Hi Ahmadi,
The spool will be equipped with a flange at both ends and would be installed inline between the PSV and related vessel.  Then, for creating isolation during maintenance, there would be no need for a spectacle blind and it's adequate to remove the spool and isolate the vessel with a blind.
#5 R.Ahmadi
R.Ahmadi
  • 10 posts
Posted 18 May 2018 - 12:24 PM
thank you
I am dealing with a spool equipped vessel, there's a spacer upstream of the spool between the vessel and psv.
anyway, thanks a lot.
Edited by R.Ahmadi, 18 May 2018 - 12:27 PM.
#6 fallah
  • 5,019 posts
Posted 18 May 2018 - 12:33 PM
If there is a both ends flaged spool between the PSV and relevant vessel there is no need to having any spacer upstream/downstream of the spool...
#7 R.Ahmadi
R.Ahmadi
  • 10 posts
Posted 18 May 2018 - 12:41 PM
great,
what's the meaning of positive isolation precisely?
#8 fallah
  • 5,019 posts
Posted 18 May 2018 - 12:52 PM
Positive isolation is simply a type of isolation in which no leakage is tolerated.  Then isolation with a valve isn't a positive isolation and isolation with a blind either by inserting it between two inline flanges or after removing a pipe spool is considered as a positive isolation.
#9 Nasreddine
Nasreddine
  • 13 posts
Posted 22 May 2018 - 06:56 AM
Hi
Please there are any docs talk about isolation process and positive in design phase?
#10 breizh
  • 6,742 posts
Posted 22 May 2018 - 05:46 PM
you may find some interest reading the document attached.
