Hello
I have a steam stripping column were my inlet stream is water with some amount of furfural. I want to get a water stream with a furfural content spec (ppm). I was getting some trouble with column convergence. I don't get a solution if I use HYSIM Inside-Out solver method (in Parameters Tab). However, I do converge the column with Modified HYSIM Inside-Out method, as well as using Newton Raphson Inside-Out method. In all the cases I am working with Peng-Robinson property package.
The problem is that with HYSIM Modified, I need only 500 kg/h of steam (and I get rid of all the furfural, getting to a mass content of less than ppb wt), but with Newton I need at least 2500 kg/h of steam to get to a content of several ppm.
Which method shall I use? Utility consumption in my plant will be quite different depending on my solving method, as well as column sizing.
Thanks in advance.
