Fire Valve
#1 ryn376
ryn376
  • 97 posts
Posted 01 June 2018 - 05:56 AM
We have vessel jackets that are filled with Multitherm PG-1 (operating temperature 550 F, design pressure 150 psig), e.g. material that will sustain a fire. According to the vendor, they do not have vapor phase physical property data for it. Additionally, at relief it will be supercritical.
Would anybody be able to provide high level information about the use of "fire valves" (meaning valves that are actuated by fire, I'm not sure if I used the correct term...)? I assume one normally open (fail-closed) fire valve closes to shut-off flow then another valve would fail open to allow the PG-1 to drain out directly onto the floor and into the fire. Is this the normal way to handle this or is there a better method?
Thank you in advance for your help and suggestions.
  • 6,940 posts
Posted 01 June 2018 - 06:58 AM
https://www.globalsp..._shut-off_valve
You may find answer in the link above.
