Positive Equipment Isolation Options
Started by soloweber, Jun 08 2018 07:33 PM
Posted 08 June 2018 - 07:33 PM
From a process point of view, what determines the best option for Positive Isolation on Equipment from these options below or others
Closed Valve.
Closed Valve with Open Bleeder
Double Block and Bleed
Block and Bleed with Line Break
Block, Bleed, and Spectacle Blind
Double Block and Bleed with Blind
Double Block and Bleed with Line Break
Thanks in advance.
Posted 20 June 2018 - 11:16 PM
While closing two valves and voiding the space between them provides very good isolation and an ability to confirm isolation, it is not considered "positive isolation" because it is not certain. Only a blind or physical removal of piping (dropping a spool) should be considered "positive isolation". The need for valving and bleeds will depend on how much of the plant you want to depressuring before swinging a blind or spool.
Posted 22 June 2018 - 02:18 AM
Alternative Career OptionsStarted by Guest_Kakashi-01_* , 24 Jul 2025 |
Best Practices For Handling 50% Hf – Equipment Failures IssueStarted by Guest_Jaydip_* , 19 Jun 2025 |
Isolation Requirement For Bypass Valves/ Movs.Started by Guest_shantanu.ghag_* , 15 Sep 2024 |
Positive Displacement Pump Psv Discharge LocationStarted by Guest_QuantumEng_* , 24 Jul 2024 |
