Dear all simulation expert
When I do the basic design stage, what is the minimum temp approach should I use for shell and tube heat exchanger design.
Best regard,
Sapao
Posted 30 June 2018 - 10:19 AM
Best regard,
Sapao
Posted 30 June 2018 - 02:54 PM
It is not a question about simulation. It is about economics.
The higher the energy cost, the lower the approach.
The higher the financial cost for your project, the more you focus on reducing equipment cost and less in ongoing efficiency.
The higher the pressure or more exotic the exchanger material, the wider the approach.
Typical:
-> 5 °C to 10 °C for Cooling Water and near ambient temperature exchangers made of carbon steel.
-> 1 °C or 2 °C are common in cryogenics (Air separation, LNG) since the cost of refrigeration is high
https://www.cheresou...nic-exchangers/
But it is you, as you specify the equipment, within the specific context of the project, who has to define the criteria. In fact, using rules of thumb guidances on this area is not a good Idea.
Edited by Saml, 01 July 2018 - 01:17 PM.
Posted 01 July 2018 - 10:49 AM
Many thank for your sharing Saml.
Sapao
Lng ExchangerStarted by Guest_guoyinyanliner_* , 10 Feb 2026 |
Best Heat Exchanger Type For Gas HeatingStarted by Guest_Gole_* , 29 Jan 2024 |
Smr Reformer Tube Hot BandStarted by Guest_kaidlut_* , 07 Aug 2025 |
