What is the effect of increasing or decreasing the subcycle time on hydrogen purity and hydrogen recovery at high feed rate or low feed rates? what is the capacity factor ?
Posted 03 July 2018 - 07:09 AM
Posted 03 July 2018 - 09:53 AM
What is a "subcycle"?
What is the "capacity factor"?
Posted 05 July 2018 - 03:01 AM
If your PSA feed hydrogen gets contaminated ( Generally with Higher amounts of Carbon monoxide etc ), reducing the PSA adsorption cycle timing is a good option to avoid the breakthrough of the contaminant as the bed gets saturated faster.
In case of normal PSA operation where you want to just ask a "What if" scenario, with the usual hydrogen feed
- Reducing the adsorption time will lead to a better product quality (unless its already at 99+ purity)
Posted 23 July 2018 - 11:31 AM
Capacity factor decides the capacity of the PSA
i.e.The maximum amount of feed gas flow which can be processed by the PSA to get the Hydrogen with design purity(also without adsorbent overloading)
For example,
Let's assume the following parameters for PSA
Design flow - 1000 Nm3/hr
design capacity factor - 1.0
If we change the capacity factor from 1.0 to 0.5
Maximum flow which can be processed by the PSA will be reduced to 500 Nm3/hr
Gas Purification Kohl PdfStarted by Guest_guoyinyanliner_* , 25 Jan 2026 |
Flow & Pressure Regulation For Compressible FluidsStarted by Guest_Abdessamed1961_* , 14 Dec 2025 |
