4
Ethylene Glycol Purification Column
chemical engineering distillation column ethylene glycol design
#1 sg21255
sg21255
Posted 19 May 2026 - 10:54 AM
I am designing an ethylene glycol purification distillation column for my final project for a 700,000 ton/year capacity my results for the column are;--- MASS BALANCE ---
Feed = 1326.74 kmol/h, zF = 0.9718
Distillate= 1289.33 kmol/h, xD = 0.9985
Bottom = 37.41 kmol/h, xW = 0.0516
MEG recovery = 99.85%
--- OPERATING CONDITIONS ---
P_top = 100.0 mmHg, T_top = 144.52 °C
P_bot = 109.56 mmHg, T_bot = 177.18 °C
ΔP = 9.56 mmHg, T_avg = 160.85 °C
--- THEORETICAL DESIGN ---
N (McCabe-Thiele) = 13 stages
Feed plate = 6 (from top)
COLUMN GEOMETRY
HETP = 0.48 m
D_top = 4.64 m
D_bot = 5.28 m
D_column = 5.28 m (standard: 5.3 m)
H_packing = 6.24 m
H_total = 13.14 m
L/D ratio = 2.48
--- PRODUCT QUALITY ---
MEG purity = xD = 0.9985 mole fraction MEG
Total MEG production = 1287.40 kmol/h “ as is it too high for 5.3m diameter for a distillation column with a L/D ratio of 2.48? I thought that maybe I can divide the unit as two column and diameter could decrease to 3.78 m something, since I did so many assumptions this is the final results what do ypu suggest?
  • 1,701 posts
Posted 20 May 2026 - 12:01 AM
For your project, I suggest checking your work, documenting your design, writing a good report. Two columns will be much more expensive than one column and I do not see the advantage of two columns. Congratulations on surviving school! The world needs more good engineers.
#3 breizh
  • 7,071 posts
Posted 20 May 2026 - 01:49 AM
To support your work.
Distillation Calculators | CheCalc
#4 ProcessAtWork
ProcessAtWork
  • 4 posts
Posted 24 June 2026 - 04:31 PM
wondering if you have the design, how did the calculator above work?
