In our steam methane reformer,we are adjusting the upstream valve of the total process steam flow control valve to control the total process steam flow whenever the load changes by more than 3-4 %.
Is this operation normal?
Actually quick opening type plug is used in the total process steam control valve.As quick opening type plug allows large amount of flow with very less opening,this could be one of the reason for the adjustment.Is this the real cause?
Does anyone using any other type of plug i.e.linear or equal percentage type in the total process steam control valve?
Or
Is there any other possible problem with our existing control valve?
Reformer Steam Control Valve In Steam Methane Reformer
Started by Refeng, Jul 24 2018 03:11 AM
No replies to this topic
Posted 24 July 2018 - 03:11 AM
Smr Reformer Tube Hot BandStarted by Guest_kaidlut_* , 07 Aug 2025 |
Automatic Choke ValveStarted by Guest_Mudassssir011_* , 22 Jul 2025 |
Converting Superheated Steam To Saturated SteamStarted by Guest_addiesalsabil_* , 10 Sep 2023 |
![]() Steam Used In ReboilersStarted by Guest_aliebrahem17_* , 05 Jul 2025 |
