Hi!
I have question. Is not a process problem for us but is something that catch my attention and I need help to explain.
First of all, we saw a water condensation (from ambient humidity) over the pipe as show in “Condensation path”.
An 18inches pipe in transporting natural gas and a condensation “path” can be seen where a 2in sidestream get into.
Operating Condition:
18” inches pipe
Pressure: 2.5 kg/cm2g (28.4 psig)
Temperature: 0-2 °C (32-28°F)
Flow: 1 MMSMCD (35 MMSCFD)
Molecular Weight: 19 (See Composition MW19)
Service: Natural Gas from Field
Ambient Temperature: Between -2 – 15°C (28-59 °F) Winter Here.
2” inches pipe
Temperature: 24 °C (75°F)
Flow: 3100 SMCD ( 105.900 SCFD)
Molecular Weight: 35 (See Composition MW35)
Service: Gas from Condensate Stabilization Column
We use a infrared camera to see temperature profile inside the pipe. It can be seen that the coldest temperature is just in the gas mixing zone, drawing the same path as condensation appears. See “infrared Picture”.
There´s any chance that, when I mix two different molecular weight gases, a kind of condensation happened taking energy from ambient? How can I explain that?
Thanks in advance!
Ariel
