I have heard Fuel Sensitivity or Octane Sensitivity . This is RON minus MON of fuel. So less sensitivity, better it is. So i want to know for heavy reformate from Refinery CCR, what can be this value ? Generally, RON is equal to MON minus 10. But for heavy reformate what is the relation. Also i want to know significance of Vapour lock index VLI.
Fuel Sensitivity
Started by CHEMSTRONG, Aug 20 2018 04:39 AM
Posted 20 August 2018 - 04:39 AM
Posted 22 August 2018 - 03:43 AM
for the VLI see, for instance
https://www.mckinsey...por-lock-index/
for RON and MON, generalized correlations have very limited use, as you can see from the attached table.
you should use plant data to avoid mistakes.
good luck!
Handheld Ethanol Fuel Content AnalyzerStarted by Guest_Sciosophy_* , 03 Mar 2026 |
Sugar Impurities After Distilling Ethanol FuelStarted by Guest_vyse_* , 14 Nov 2024 |
Hydrogen Fuel CellStarted by Guest_rednaxela_* , 09 Mar 2023 |
Aspen Plus - Sensitivity Analysis / Case Study - Need AssistanceStarted by Guest_SickPuppy0_* , 07 Feb 2023 |
Diesel FuelStarted by Guest_CHEMSTRONG_* , 24 Feb 2022 |
