Why is paraffin oil used for seal of NBL (n-butyllithium) vessel flash vapor?
Flash Vessel Seal Fluid In Polybutadiene Plant
Started by ebrahimtemraz, Aug 30 2018 07:46 AM
No replies to this topic
Posted 30 August 2018 - 07:46 AM
Lpg Plant DesignStarted by Guest_betulche_* , 08 Mar 2026 |
Air Separation Plant DesignStarted by Guest_adda_* , 03 Mar 2026 |
Supercritical Fluid Flowrate - He Tube RuptureStarted by Guest_flarewolf_* , 07 Apr 2025 |
