I have been challenged to design a system to remove gas from vapor hydrocarbon using water wash similar to the crude unit overhead system. I am new to this area and had no previous knowledge on desing of scrubbers or spray nozzle. The idea I have is to treat the piping that carries the vapr as a scrubber and design the spray nozzle to improve the efficeincy of the gas removal.
I will appreciate any ideas, references or help in this issue.
Frank
Spray Nozzle Scrubber Design
Started by Frank, Sep 12 2006 12:05 PM
Posted 12 September 2006 - 12:05 PM
Posted 13 September 2006 - 12:20 AM
Frank
You might want to run a HYSYS or VMG simulation (or on any other simulator) and determine the degree of hydrocarbon removal from the vapour stream. This will predict the hydrocarbon concentration in the vapour stream downstream of the scrubber.
One configuration for a scrubber system, is to spray the vapour, collect the scrubbing liquid in a tank and then recycling the scrubbing liquid until it is saturated, where upon you replace the liquid or strip the hydrocabons from the scrubbing liquid.
Running the simulation with various options will help you in determining which configuration is the best suited to your conditions.
Hope this helps
Francois
Hope this helps
Francois
![]() Scrubber DesignStarted by Guest_nasss_* , 07 Aug 2024 |
Scrubber(Absorber) In Apsen PlusStarted by Guest_Seonwoo_* , 20 Mar 2025 |
![]() Heat Exchanger Network DesignStarted by Guest_Kakashi-01_* , 21 Feb 2025 |
