Produced Water Treatment Train
13 replies to this topic
#1 eng.eslam87
eng.eslam87
  • 6 posts
Posted 02 October 2018 - 05:18 AM
HI
I want to know if there is a simulation software which enable me to simulate a Produced water treatment train containing CPI and IGF "induced gas flotation" and nut shell filters
#2 Technical Bard
Technical Bard
  • 407 posts
Posted 04 October 2018 - 01:12 PM
No.  These are physical separations, not thermodynamic ones.  You can easily build your own calculation models from first principles for CPI separators.  You will need vendors for IGF and nutshell filters.
#3 eng.eslam87
eng.eslam87
  • 6 posts
Posted 08 October 2018 - 01:13 AM
Is there any way to simulate these processes for sizing and calculating cost for beginning?
#4 thorium90
thorium90
  • 1,073 posts
Posted 08 October 2018 - 11:23 AM
You don't need to create a simulation of its operation to get its sizing and cost.
#5 eng.eslam87
eng.eslam87
  • 6 posts
Posted 10 October 2018 - 01:09 AM
Okay then, is there any software to help me in estimating the cost and sizing...
I will really appreciate your help
thank you
#6 breizh
  • 6,907 posts
Posted 10 October 2018 - 05:00 AM
the only way is to prepare the specification sheets with relevant balances for the vendors to size the equipments and provide a budget price .
#7 thorium90
thorium90
  • 1,073 posts
Posted 10 October 2018 - 06:55 AM
Out of curiosity, what is the purpose of this exercise? Are you building a new plant? Or is this just for better understanding of the existing plant?
#8 eng.eslam87
eng.eslam87
  • 6 posts
Posted 11 October 2018 - 08:15 PM
i'm working in an old oilfield with only API separator to treat the produced water before disposal, and with the increased volume of the produced water, a new treating system is needed,,
And i need something to help me to calculate equipment size and installation cost..... basically and roughly...
Thank you
#9 thorium90
thorium90
  • 1,073 posts
Posted 11 October 2018 - 08:36 PM
Sizing and costing, I would suggest you get someone more experienced to do or work with a vendor . For rough guidance, the following guide should be useful for you.
Edited by thorium90, 11 October 2018 - 08:36 PM.
#10 eng.eslam87
eng.eslam87
  • 6 posts
Posted 19 October 2018 - 05:40 AM
Please friends
can anyone help me with calculating the cost of the CPI, Hydro-cyclone, the nutshell filter?
I can't find any helpful data on the internet
#11 breizh
  • 6,907 posts
Posted 19 October 2018 - 06:46 AM
hi ,
As I stated in a previous post you need to prepare  specification sheets to get quote from vendors ! Again if you want help from the forum members you should be specific .
We have no clue about your process , the flow rate ,the size , the material the equipment should be made of , etc  to give you a piece of advice .
Your filter should be a Nutsche filter !
Hope you understand and good luck..
Breizh .
#12 eng.eslam87
eng.eslam87
  • 6 posts
Posted 20 October 2018 - 03:53 AM
sorry about the insufficient info Breizh
the produced water flow rate is  90,000 BPD
the water analysis
Oil and grease content
567  PPM
pH
6.35@ 25 oC
Total Dissolved Solids
148345.3 mg/l
Density
1.13069 g/ml @ 60 F
Total Suspendid Solids
139 mg/l
Specific gravity
1.13182
Conductivity
19.55 X10-2 mohs/cm @ 23.4 oC
Hardness as CaCO3
21319.6 mg/l
Resistivity
0.0512 Ohm-m @ 23.4oC
Alkalinity as CaCO3
40.0 mg/l
Salinity as NaCl
148835.0 mg/l
It is required to reduce the oil content to less than 10 ppm
and to reduce the suspended solids to less than 5 mg/l
It is required to install Two treatment train each consist of CPI followed by hydrocylone followed by a media filter " for example  walnut shell filter .." the design capacity for each train should be 50,000 BPD
i want to calculate the capital cost and the operational cost for this system..
your help is highly appreciated..
best regards
Eslam
Edited by eng.eslam87, 20 October 2018 - 04:10 AM.
#13 breizh
  • 6,907 posts
Posted 20 October 2018 - 05:26 AM
Try to get a copy of the book in reference : gas-liquid and liquid-liquid separator by Maurice Stewart and Ken Arnold .
Hope this is going to put you in the right direction .
#14 thorium90
thorium90
  • 1,073 posts
Posted 20 October 2018 - 06:19 AM
With the WW info that you have just given, your proposed process of CPI, IGF and nut shell filters is definitely not suitable.
No offense, but you clearly do not have the info and expertise required to even select the correct process treatment, why are you being arrowed to do this?
If the plant does get built with what you have proposed, it would become a white elephant as the process clearly will not meet the treatment requirements.
If you are being arrowed for the task, I would suggest to find and work with someone with the required expertise.
I think the first step is for you is to do a proper wastewater characterization, then based on this wastewater information, come up with a design basis. From this design basis, come up with different possible process combinations and evaluate them. The evaluation should include the capability of achieving the treatment requirement. With the process flow scheme decided upon, you can then start to get budgetary quotations from vendors to help in your compilation of CAPEX costs.
You current proposed process will not be capable of meeting 10ppm oil and 5ppm TSS, so there is no point to go to the next step in calculating the CAPEX and OPEX of the system.
Edited by thorium90, 20 October 2018 - 06:33 AM.
