Hello everyone! I want to ask you a (most probably basic) question related to the steam.
Generally saturated steam is steam that is used in equilibrium with heated water at the same pressure. Similar definition can be given for the saturated water.
So my question is if I want to simulate a saturated steam in an simulation software, I can use vapor fraction 1 and the pressure? And for saturated water, I can define vapor fraction 0 and the pressure?
Thank you in advance!
