Dear All
I need your expertise on the above topic.
Actually I have a task to replace the Modulating LCV with ON/OFF LCV combination with RO in the rich amine line at the amine contactor bottom. I am confuse because this may cause problem during operating. The rich amine from the contactor will carry heavy HC and suspended particles which may plug in the RO bore. As we know that Carbon filter is used to remove the particles from the Rich amine. So its mean rich amine contain some unwanted components. But due to the Pressure difference, this plugging may not occur. Because Flash tank and Amine contactor pressure difference is very high so the some particles will flow without choke the RO bore.
Please advise if I can suggest to install in the replacement of Modulating LCV with Restricted Orifice (RO).
Edited by 12345656, 24 October 2018 - 08:11 AM.
