Hi All
I am an application engineer working for fuel gas treatment project. Please advise on the below query
The gas composition is given to me contains the following
Methane, Ethane, Propane, i-butane,n-butane, i-Pentane, n-Pentane, n-Hexane, H2S, Co2, Nitrogen, M-Mercaptan, E-Mercapatan, diM-Sulphide, 2C3Mercaptan, t-B-Mercaptan,2 Butanethiol, nBMercaptan, and the heavy components (hypo components) at the below mentioned conditions
Operating conditions
Pressure- 4 barg
Temperature- 77 Degree Celsius
The above gas composition consists of the chloride content of 1,45.216 mg/lit of water and liquid carry over of 0.1 Usgal/MMSCF
Can I Include the Cholride content by converting 1,45,216 mg/lit to 14.522 percent and include in the composition stream (in hysis ) and normalize it , if the composition is exceeding 100%?
As only the liquid carry over of 0.1 Usgal/MMSCF is given, and the output composition from the chemical treatment package should contain only the following
H2S ppm < 500 PPM
Chloride content <600 mg/l
1. Please advise how to insert liquid carryover into composition in hysis, Can I use Mix option or insert directly in the composition stream and normalize it?
2. What liquid can i consider? As the Gas is removed from the well pad and subsequently treated for liquid removal in three stage separator. Further it enters Fuel gas treatment package which i need to develop
Please advise on this......
Thank you for the help in advance
B.Vinodh Kumar
I
