hi,
i wanted to understand the operation of a choke valve in gas lift and in general. Is this valve for pressure control and is it equal to globe valve?
Posted 17 November 2018 - 07:59 PM
hi,
Posted 17 November 2018 - 09:27 PM
https://www.enggcycl...3/choke-valves/
from your favorite engine.
Hope this is helping you.
Posted 29 November 2018 - 06:00 AM
This topic is very useful, Just to add in this topic that the Choke valve should be angular or inline. What is the criteria.
Thermal Relief Valve For A Fire CaseStarted by Guest_QuantumEng_* , 19 Nov 2025 |
Real Or Ideal Cp/cv For Control Valve CalculationsStarted by Guest_sumwunrandom_* , 14 Oct 2025 |
Automatic Choke ValveStarted by Guest_Mudassssir011_* , 22 Jul 2025 |
