Hello All,
I have one system which I need to understand regarding PSV calculation.
First I wanted to know that how we can find out degree of super-heat in difference of 2 temperatures.
For example: If I want to calculate the flow across the control valve for CV Failure case based on control valve Cv value, I need to give the input of degree of super-heat which is based on temperature/pressure value across the control valve.
So in that case, how can I enter the degree of super-heat value for the same.
Second:
In case of I am calculating CV failure case, which flow rate I have to take for the orifice size calculation?? Is it of max fluid flow rate value (i.e. steam or any liquid) or calculated Cv value it should be arrived??
Please suggest..
Thanks & Regards
Rahulkumar Maurya
